LTE7490-M904 default admin password after upgrade
sviykaz
sviykaz Posts: 11
edited January 2024 in Mobile Broadband
I managed to upgrade an LTE7490-M904 from firmware version 1.00(ABZK.0)C0 to 1.00(ABQY.6)C0. All worked fine (web UI, connections, everything) until I had to hard reset the configuration. Now the router is visible on the net (bot LAN and WiFi), but any admin password I try is not valid. Tried with the one printed on the label, with "1234", "12345678", "admin" and empty - nope. How can I get my router back?
Thanks!
S.
«1
  • SELBERG
    SELBERG Posts: 373  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    edited July 2023
    Try a power off of your 7490 for about 2 minutes.....
  • sviykaz
    sviykaz Posts: 11
    Thanks, but no way. I have access to the UART console, all is fine except admin password…
  • SELBERG
    edited July 2023
  • sviykaz
    sviykaz Posts: 11
    Yes, of course! :-)
  • SELBERG
    edited July 2023
    Any changes with login 192.168.2.1
  • SELBERG
    If you did your hard reset in web GUI try if possible to do it instead on your unit!
  • sviykaz
    sviykaz Posts: 11
    Nope. Router WEB interface on WiFi is on 192.168.1.1, on LAN it's on 192.168.2.1 - but admin password is not valid on either interface (including UART console)
  • sviykaz
    sviykaz Posts: 11
    Made hardware reset, but the admin pwd on the label is not accepted as valid, nor is any of the "known to be good" ones…
  • SELBERG
    edited July 2023
    Is it possible to do a hard reset again on your unit? Press @ least 15 secs with a pin in the hole.....
  • sviykaz
    sviykaz Posts: 11
    Yeah, tried several times, no change.
    My guess: older firmware used a hard-coded password, new firmware uses an algorithmically generated password (i.e., based on modem serial number, like in VMG8825).
    Is there a possibility for someone to generate such a password, given the relevant data (modem S/N, MAC addres or whatever)?
