Does NR7101 support SHA256 as a Thumbprint Algorithm for SSL/TLS Certificates?
tonygibbs16
Does NR7101 support the SHA256 hashing algorithm as the Thumbprint Algorithm for SSL/TLS certificates?
The user guide available at https://www.zyxel.com/uk/en-gb/support/download?model=nr7101 says that it only supports MD5 and SHA1.
Yet MD5 and SHA1 are proving to have weaknesses as hashing algorithms.
Kind regards,
Tony
User Guide downloadable at https://www.zyxel.com/uk/en-gb/support/download?model=nr7101 in section 18.7.1 says MD5 and SHA1.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
