NR7101 Module upgrade
My module verion is now: RG502QEAAAR11A03M4G
Do I have to install these one by one:
RG502QEAAAR11A03-R11A06 | Modem Code File | Download Now! |
RG502QEAAAR11A06M4G-R11A07 | Modem Code File | Download Now! |
RG502QEAAAR11A07M4G-R13A02 | Modem Code File | Download Now! |
Or can I just install the latest?
Where can I found change log for these upgrades?
Best Answers
Do a factory reset between every upgrade in the following order.
Maintenance // Backup/Restore/ and scroll down to // Back to Factory Default Settings // and hit reset button.
Hi @jgr
I think that you have to do all of them in sequence, i.e. upgrade to R11A06 then upgrade to R11A07 then upgrade to R13A02.
I think that the DFOTA module upgrade files only work with this sequence.
Then you will have the latest module firmware R13A02.
Kind regards,
Tony
Hello @jgr
Welcome to the forum.
You have to install them one by one and in order, so you upgrade to R11A06 first, then upgrade to R11A07, and then upgrade to R13A02.
The R11A07 release notes are at https://us.v-cdn.net/6029482/uploads/editor/uv/vttwhdse7tik.pdf
The R13A01 release notes are at https://us.v-cdn.net/6029482/uploads/editor/46/oi26a2hnk2ta.pdf
Kind regards,
Tony
So if I now have R11A03, should I next upgrade to R11A06 → R11A07 → R13A02, and that would be the latest for now?
Or did you mean that I can skip the R11A06 and upgrade from R11A03 →R11A07 → R13A02
BR,
Jan
Hi @jgr
Kind regards,
Tony
I suppose this module upgrade is not compatible with NR5101 when will be an upgrade for that model?, I cant even conect or recognize SIM broadband on operators like Orange ( In Spain ) my NR5101 only recognizes Movistar operator and Vodafone.
- 588 USG FLEX H Series
- 477 News and Release
