[USGFLEX50] Upgrade Firmware failed
Good morning, I have to update the firmware of a USGFlex50 from version 5.30 ABAQ.0 to 5.36 ABAQ.2, but every attempt is unsuccessful. I've tried updating via cloud, via ftp, manually. I have no error, simply the firewall does not complete the procedure. Even restarting the firewall I always have version 5.30 ABAQ.0. How can I fix? Thank you Matteo
You can download 5.31 and 5.32 here
unplug from WAN reboot then upgrade might help
I tried upgrading to 5.31 and 5.32 (with reboot), but the firewall won't reboot and the 5.30 firmware remains.
Hi @MatteoDS
You could refer to those articles:
(1). What should I do if the device failed to be upgraded to the latest firmware?
(2). Recovery steps if you cannot update the firmware in the running partition
Thanks.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
