USG problems after latest firmware update
After the latest firmware update to V5.37(ABWC.0) (Latest), one ours USG Flex 100W is always reporting its configuration as: Not up to date, require upgrade to latest firmware.
Also its L2TP over IPSec VPN server is no longer working, without any configurations changes from our part. This is the error reported in windows
What is going on?
I have the same situation.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgentNuovo dal menu Modifica e quindi valore DWORD (32 bit)
AssumeUDPEncapsulationContextOnSendRule
Dati valore 2
Guarda, dopo un terzo riavvio del firewall in questo preciso momento ha ripreso a funzionare…
Same issue here, my customers are complaining that they can not connect to their VPN anymore.
It was the case before the latest update, so I tried this update as a mitigation but it does not work better after the update. I also tried to switch from the Default policy to another but nothing seems to work.
We have implemented the registry hack to allow NAT traversal, it has been done years ago.
Could you please solve this ASAP because some peaople are "remote workers" waiting their connection.
Please also note that nothing has changed in the configuration, not on Nebula nor on the client.
We have several customers experiencing this issue on USG Flex 100. Site-to-site VPNs are working via the ochestrator, remote access VPn only seems to be concerned.
Super! I have exactly the same problem. I have only 4 gateways of which 2 gateways have been updated and 2 cannot update to the latest version V5.37.
VPN also does not connect, and moreover, VPN between gateways also stopped working.
Is there a solution to the problem?0 -
Hi @Dylan96 @Zollie1970 @FrancescoMinelli @Sébastien @Georg7
We re-pushed the VPN configuration file to devices yesterday. The VPN connection should be able to be connected. If the issue still exists, please follow this guide to send Org/Site to us by private message.0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
