NR7101 Module upgrade
jgr
jgr Posts: 4
edited January 2024 in Mobile Broadband
My module verion is now: RG502QEAAAR11A03M4G
Do I have to install these one by one:
RG502QEAAAR11A03-R11A06
Modem Code File
Download Now!
RG502QEAAAR11A06M4G-R11A07
Modem Code File
Download Now!
RG502QEAAAR11A07M4G-R13A02
Modem Code File
Download Now!
Or can I just install the latest?
Where can I found change log for these upgrades?
Best Answers
  • SELBERG
    SELBERG Posts: 363  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Do a factory reset between every upgrade in the following order.
    Maintenance // Backup/Restore/ and scroll down to // Back to Factory Default Settings // and hit reset button.
  • tonygibbs16
    tonygibbs16 Posts: 971  Guru Member
    edited July 2023 Answer ✓
    Hi @jgr
    I think that you have to do all of them in sequence, i.e. upgrade to R11A06 then upgrade to R11A07 then upgrade to R13A02.
    I think that the DFOTA module upgrade files only work with this sequence.
    Then you will have the latest module firmware R13A02.
    Kind regards,
    Tony
  • tonygibbs16
    edited July 2023
    Hello @jgr
    Welcome to the forum.
    You have to install them one by one and in order, so you upgrade to R11A06 first, then upgrade to R11A07, and then upgrade to R13A02.
    The R11A07 release notes are at https://us.v-cdn.net/6029482/uploads/editor/uv/vttwhdse7tik.pdf
    The R13A01 release notes are at https://us.v-cdn.net/6029482/uploads/editor/46/oi26a2hnk2ta.pdf
    Kind regards,
    Tony
  • jgr
    jgr Posts: 4
    So if I now have R11A03, should I next upgrade to R11A06 → R11A07 → R13A02, and that would be the latest for now?
    Or did you mean that I can skip the R11A06 and upgrade from R11A03 →R11A07 → R13A02
    BR,
    Jan
  • SELBERG
  • tonygibbs16
    Hi @jgr
    Kind regards,
    Tony
  • ViX
    ViX Posts: 4
    I suppose this module upgrade is not compatible with NR5101 when will be an upgrade for that model?, I cant even conect or recognize SIM broadband on operators like Orange ( In Spain ) my NR5101 only recognizes Movistar operator and Vodafone.
