Connected Clients always zero
thierma
thierma Posts: 2
edited November 2023 in Nebula
There are no clients shown in the Nebula Dashboard on any Accesspoints.
How can i fix that? Is Nebula Pro Pack needed?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @thierma
    You don't need the Nebula Pro Pack for the Current Client to work.
    To help troubleshoot this issue, could you please check the following:
    • Cloud Saving Mode: Please check if your Organization is currently in Cloud-saving mode. If it is, you can disable it on the top banner. Cloud_Saving_Banner.PNG This happens when you do not log into the organization for over 30 days, the organization automatically enters Cloud-saving mode to save the network bandwidth and cloud resources.
    • NTP: Please check if the firewall rule is blocking NTP. This could prevent Nebula from displaying connected clients.
    • Device Connections: Check if there are any devices connecting at Devices > choose the specific device > Live tools > Current stations tab. This can help determine if the issue is with the dashboard or the actual connections. Device_Livetools_Current.png
    Please let us know if these steps help resolve your issue or if you need further assistance.
    Nami
  • Zyxel_Nami
    Hello @thierma
    Nami
  • thierma
    thierma Posts: 2
    Thank you very much for the hint disableing the cloud service. That worked for me. After a few minutes it showed up the connected clients.
Nebula Tips & Tricks
