NR7101 5G speed
danielruppen
danielruppen Posts: 10
image  Freshman Member
edited January 2024 in Mobile Broadband
Hi
I use a NR7101 with the following settings:
Firmware: V1.00(ABUV.8)C0
Module version: RG502QEAAAR11A03M4G
Cellurar Band: Auto
Band Auto selection
IP Pass Through Mode
On the system info page it states %G connection
My issue is speed. Regardless whether I run the speed test on the NR7101 or on my router Unifi dream machine pro, I never get more than 90 Mbits
However if I run a speed test with an Android or iPhone (e.g. iPhone Pro 13) I easy get 300Mbits download speed
Has anyone experienced the same and is there a solution?
Many thanks
Daniel
«1
  • Friday
    Friday Posts: 114
    5 Answers First Comment Friend Collector Third Anniversary
    image  Ally Member
    Hi @danielruppen ,
    Are you using NR7101 speedtest function on GUI or a Ookla speedtest?
    And both Zyxel and Unifi has the speed issue mentioned?
    thanks!
  • danielruppen
    Hi
    I use the 7101 speed test on the GUI, Oakia and also the Unifi speed test
    On my iPhone I use Oakia spehd test only
  • tonygibbs16
    tonygibbs16 Posts: 979
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    image  Guru Member
    edited July 2023
    Hi @danielruppen
    It might be worth you upgrading your module version, to at least R11A07 using the modem code files (also known as DFOTA files) available at https://support.zyxel.eu/hc/en-us/articles/4403365084818-5G-Devices-Advanced-Downloads-Firmwares-and-other-resources-
    as that might improve your performance.
    The R13A02 module software then includes 5G Channel Aggregation as one of its changes.
    Kind regards,
    Tony
  • monstrmprz
    monstrmprz Posts: 37
    First Answer First Comment Friend Collector Third Anniversary
    Update the module firmware and i'm sure that the iphone using different bands than the router. Try enable/disable bands. Navigate to cellmapper.net website to see the 4G/5G bands on your location with your provider.
    Noob question: isn't there a cat5 or older cable after the nr7101, right?
  • danielruppen
    I've tried that but unfortunately it didn't help. Many thanks for the module upgrade hint
  • danielruppen
    It's a standard cable, assume it's CAT5. Do you think it could be the cable?
    Re bands: thanks, I've just checked and it tells me 3,20 but I'm a bit lost to set this parameter. It's in Network settings→Cellular Lock (5G), right but do I have to set now? Enable PCI? and then?
  • danielruppen
    Hmmm, your question re CAT cable let me check my PEO Injector which is very old and I don't have the specs. I have now ordered a new one with enough power and Giga throughput. It will arrive on Monday and I will test and revert back
  • SELBERG
    SELBERG Posts: 375
    5 Answers First Comment Friend Collector Fifth Anniversary
    image  Master Member
    edited July 2023
    Check this!!!
  • monstrmprz
    edited July 2023
    Check what SELBERG said. You need Gigabit connection to earn more speed than 100Mpbs. If you have a device In your network (switch, POE injector or an old cable, that only support Fast ethernet (100Mbps)), the speed will be slow (Max ~90-100Mbps). The unifi is support gigabit so you need check what devices/cables are between the nr7101 and unifi. Anyway what show the unifi to the link speed in your settings? Gigabit?
    If the link is 1Gbps:
    Try enable/disable different bands also in the settings and try again. Try the bands that are available at your location. Network setting - Broadband - Cellular Band. Turn off auto selection and play with bands.
    I've seen CAT5 cable that only support 100Mbps. You need min. CAT5e. The CAT5 is support gigabit in few meters too, but long cables surely not support.
    I hope the new POE Injector is solve your problem!😊
