Nebula Cloud Service Incident 2023-07-18, 09:17~11:46 (UTC+0)
Zyxel_CSO
Zyxel_CSO Posts: 507 image  Zyxel Employee
5 Answers First Comment Friend Collector Ninth Anniversary
edited September 2023 in Nebula Status and Incidents
Dear Nebula Users,
The system has been temporarily unavailable due to an outage incident.
Issue Started from:
2023-07-18 09:17 (UTC+0)
Resolved:
2023-07-18 11:46 (UTC+0)
Issue Symptom & Risk:
1. NCC web pages are unable to load information
2. NCC is unable to provision or update network settings to Nebula devices.
3. NSG online event is not working
4. Changing Access Point's hostname on NCC won't be applied to the device.
Note: This incident does not affect Nebula devices and their local network services if there is no any configuration change.
If you observed any issues that do not match the symptoms & risks mentioned above, please contact @Zyxel_CSO
We apologize for any inconvenience this has caused.
Zyxel Nebula Support
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    Any ETA on a fix?
  • ItMerc
    ItMerc Posts: 8 image  Freshman Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    Looks like the service is available again.
  • Zyxel_CSO
    Hi @Pook
    We are currently in the process of fixing it. Once a resolution time is determined, we will update our post. Thank you.
  • Zyxel_CSO
    Dear Nebula Users,
    The Nebula issues have already been resolved. Thanks.
  • Pook
    Can we get any info on what caused the issue?
  • Zyxel_CSO
    Hi @Pook
    Thank you for your inquiry. We are currently working on clarifying the matter internally. Once there is further progress, we will provide you with an update. Thank you!
  • Zyxel_CSO
    Dear @Pook and other Nebula users,
    The root cause is that the function AP hostname config cause the server busy. We temporarily disable this function, changing Access Point's hostname on NCC won't be applied to the device, and is under fixing. We will update you once this issue is fixed or any further information.
  • Zulgrib
    Zulgrib Posts: 48 image  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    Could Zyxel consider to have an on-prem version for end customers and MSP to install to avoid "busy servers"?
  • Zyxel_CSO
    Dear Nebula Users,
    Issue "Changing Access Point's hostname on NCC won't be applied to the device." has been fixed.
