USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
Hi @RAUL,
If you're using USG20W-VPN, you can download the firmware to verify the issue.
USG20W-VPN
https://www.dropbox.com/s/gxgtlys7tyfuikf/432ABAR0ITS-WK43-r86079.zip?dl=0
If the issue still persists after upgraded to 432ABAR0ITS-WK43-r86079, please share the symptom, configuration file and how you reproduce the issue with us to find out the root cause.
Thank you Emily, I will get back around Christmas, hopefully the new release will be under the tree.Zyxel_Emily said:Hi @Elek,
The bug fix for Wi-Fi stability issue will be merged into the official firmware 4.33 which will be released in late December.
Same issue here too. Installed version 4.32 WK43 r86079. Will check. Awaiting the official release end of December.
Thank you.
After running the 4.32 WK43 r86079 version for a couple of days my iPhone got disconnected again. Reconnect says the password is incorrect. Waiting for 10-15 minutes solves the issue. So issue seems to be not fixed by this version.0
Check on the new release.
Hi @alehzn,
The fix for the issue "It shows wrong password on the wireless client and unable to connect to WiFi successfully." is already merged to 4.32 WK43.
Can you check "Band Select" is enabled or disabled on the SSID profile?
Hi @Zyxel_Emily
I can't find that setting on my USG20W-VPN. Where can I find it. In the meantime I will install the new release posted by @jonatan
Hi @alehzn,
Please upgrade to the version posted by jonatan and check the Wi-Fi status.
If the issue still persists, please send your configuration file to me via private message.
Hi @Zyxel_Emily
Thank you for your reply. I have successfully upgraded to the version posted by @jonatan
Will keep an eye on the WiFi status and text you in case the issue still persists.
I am still running 4.25 as the last stable version after trying multiple "custom" FW releases in the past months, is this ever going to be fixed or should we just give up and change vendor?0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
