Connectivity failure with Amazon Blink cameras
RichardY
in Home Router
I have recently had a DX3301-T0 router installed by my new ISP. However I’m unable to connect Amazon Blink cameras. Looking for suggestions to fix the problem
hi same for me - did you get any joy?
The answer lies in setting a static DNS on the LAN - Primary: 8.8.8.8 and Secondary: 8.8.4.4.
If you log in to the router 192.168.1.1 using the admin login. I you go to the bars top right and go to home networking. DNS is there and you need to change to static on LAN and set primary and secondary
thanks will try.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
