USG20 VPN setup
Im bit new about configuring any router/firewall. I managed to setup SSL VPN and connect with secureExtender to it. But My ip remains same what i use without VPN.
There is so many setups that im not sure anymore that what else i have to do to get my VPM server ip in use for my client?
Hi @Biletti,
Go to CONFIGURATION > VPN > SSL VPN > Access Privilege and click "Add".1. Create a new user.
2. After the new user is created, move it to “Selected User”.
3. Create an IP pool for SSL VPN users. Note that the subnet cannot conflict with any WAN/LAN/DMZ/WLAN even if they are not in use.
4. Select SSL_pool as Assign IP Pool. In Network List, select which subnet can be accessed by the SSL VPN users.
5. On SecuExtender, enter the USG’s WAN IP, username and password you created on the USG.
SSL VPN is connected.
Hi @Zyxel_Emily
Thanks for quick reply!
I have managed to do that, i can connect to my SSL VPN via secureexnteder client, but mu public ip is still different as my server?
It should be same as the server ip?
Hi @Biletti,
Enable “Force all client traffic to enter SSL VPN tunnel” and the SSL VPN client’s IP address is the same as USG20-VPN’s IP.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
