[NEBULA] NSG100 / LTE3301-Q222/ Bridge trouble
mark.vijgen
someybody happens to know why this setup
NSG100 on wan1 port to lan port LTE3301 device.. In normal mode give's no IP to the NSG...
and if setting the lte in bridge mode (and entering the information to the webgui of the NSG of the PPOE connection works, but after a power down, nothing works anymore, because the ip of the LTE changend! How to overcome this issue??
thanks for the help
thanks for the help
Hi @Mark_DUTCH
There's a known issue, when PPPoE has been configured and the NSG is power cycled, the NSG doesn't keep the configuration after rebooting. A new firmware that fix this inconvenience will be release in May.
Please help to check the PPPoE configuration after the power down to be sure that it's related to this issue.1 -
Dear Bayardo ,
This is exactly what happens yes... So then the problem is already known... I hope they fix this quick
Dear Mark,
Yes, we are working on it and will deliver it pretty soon. Thanks for your patience
can someone help me please where to set the PPPoE parameters on an NSG?0
Hi Peppino,
You can configure it in the local Web GUI of the NSG.0 -
ahh ok, thanks.0
- 441 Beta Program
- 293 Service & License
