Does USG FLEX 100 firewall needs a subscription for work?
Asterdebian
Asterdebian Posts: 1 image  Freshman Member
edited August 2023 in Service & License
Does USG FLEX 100 firewall needs a subscription for work? Or potentially can work without it? We only need to make VPNs
Thank You
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited February 2023 Answer ✓
    Welcome to the Zyxel community. Basically, the VPN services(such as site-to-site VPN, and remote access VPN) don't need an extra license and can use by default. USG Flex 100 has Content Filter, Anti-MAlware, IPS, App Patrol, etc. useful security services. If you got the brand new device and register the device, you will have trial license services of 30 days. So, we encourage you can use those security services during the trial license status, once the trial license is expired and you think those features are useful to you. You can purchase our license on the Marketplace to extend your license service. Besides, you could contact our local partner to purchase the device and for post-sale support. Thanks :) .
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    No, the subscription part is usually just for the extra features; e-mail filtering, malware & virus scan, Nebula Pro cloud management and so on. Regular use and configuration for standard network operation does not require any subscription. Just make a note of the device features available in the GUI and how to notice when the default/built-in subscription runs out ( ≈ 1 year).
  • smb_corp_user
    Also worth noting, in case you have not planned it already: keep the firmware version as similar and updated as possible, to avoid future confusion between the configurations.
  • Zyxel_Jeff
  • Heimo
    Heimo Posts: 5 image  Freshman Member
    is it possible to license only email and anti malware?
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 407 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Heimo,
    To purchase the individual license for your FLEX 100, you can untick the package,
    then choose the individual license you need.
    Ivan
Service & License Help Center
