NR 7101 - Issue with providing internet to my switch
I have NR7101 - Connected to a Zyxel Switch l GS1200-5HPv2.
It only provides internet access to one of the ports on the switch. What do I need to do one the NR7101 or on the switch so i can get Internet access on all ports on the switch?
I haven't done any configuration on the switch, I have also tried another TP-Link switch, which has the same issue.
Please help me to fix this.
You'll need a router to deliver the NR7101's internet to more than one device. A switch alone won't do it.
Ok, so I need to put 7101 cabel in to the router first. Then I connect the switch to the router?
Yes, that should do it
Ok, I thought that it was a 5G router and it would work only with a switch.
Any suggestion of what easy router I should use ? Good price and easy to manage.This is how my setup looks like.
1- Zyxel NR7101 - Goes into a rack where the fuses to the house are located.
from the same place/cabinet I have lan ports that goes out to the house.2- I have TP-Link switch D-link DGS-1100-08 gigabitswitch 8 ports
3- I have a Ubiquiti Amplifi HD Mesh-router AC1750 in my living room - which will be my heart for adding smart products and providing WI-FI to the house.
How shall I set this up, to make it work best.0 -
I have the following configuration and it works very very good.
I think you need to manage your switch, my is a unmanaged switch which work out of box.
My switch power up (48V) both the NR7101 and my outdoor wifi antenna.
I don't need any separate poweradapters.
You're right, that zyxel sells the NR7101 as 5G 'router', but it has very limited routing capabilities and protections (including firewalls)
That is why I would do it the other way round than suggested above. i.e.
NR7101 -> router -> switch -> other devices
Your NR7101 provides internet to your router, which decides how traffic is managed to and from your devices and your switch lets you plug in more than one device.
Hi Selberg
Do you have any injector inbetween your NR7101 and Switch?
Thank you0 -
A PoE+ switch power up my unit, no need of a injector.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
