I cannot register my new device because "This device already registered to another account"
neukrisz
neukrisz Posts: 5 image  Freshman Member
edited November 2023 in Nebula
Dear Community,
I'm newbie here, but I have a huge problem and please help me…
Recently I bought two used GS1920-24HPv2 could managed switches from a private seller who advertised them as "restored default state / reset OK".
Unfortunately I cannot register one unit from two in my account because I got this error message: "This device already registered to another account"
I contacted with the seller who said that both units were successfully reset and should work…
What can I do now?
Many thanks in advance!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,929 image  Zyxel Employee
    Hi @neukrisz,
    This is because the previous user still owns the used GS1920 although it does not in any organization.
    Please download the Nebula Mobile APP Android / iOS and scan the QR code sticker on the device to register.
    Zyxel Melen
  • Zyxel_Melen
    Hi @neukrisz,
    Zyxel Melen
  • neukrisz
    Many thanks for the advice!
    Finally solved :)
  • GianniM
    GianniM Posts: 3 image  Freshman Member
    ho lo stesso problema non riesco a registrare il mio 710 mi da il seguente errore: "Questo dispositivo è già registrato su un altro account" ho provato a registrarlo con l' APP di nebula ma esce questo errore: "Impossibile trovare il dispositivo"
    Come posso fare? il router è stato comprato nuovo su Amazon il 23 gennaio 2025.
  • Zyxel_Melen
    Hi @GianniM,
    Ti invierò un messaggio privato per richiedere le informazioni sul dispositivo per verificare questo problema.
    I will send you a private message to request the device information to check this issue.
    Zyxel Melen
Nebula Tips & Tricks
