5G home/office network scenario... it will work?
Hello everyone,
I would like to build a home/office network with these devices:
* 5G router NR7102
* Managed switch XGS1210-12
* Switch MG-108
* Access Point NWA50AX Pro
The 5G router is connected directly to the 2.5 Gbit port on the switch XGS1210-12.
The switch, on the other hand, is connected via an adapter SFP/RJ45 to the unmanaged switch MG-108 and, through this one, is connected to the access point NWA50AX Pro.
Do you think it will work? Do you have any suggestions?
Thank you all
Hello @paolocesari
Welcome to the forum.
Your application might work.
It is similar to scenario 1 on https://support.zyxel.eu/hc/en-us/articles/4405021651730-5G-Routers-How-to-use-it-troubleshooting
Kind regards,
Tony
Hello @paolocesari
Kind regards,
Tony
- 588 USG FLEX H Series
- 476 News and Release
