Nebula Device status On, but cannot reboot device today
Cyber_IT
Cyber_IT Posts: 20  Freshman Member
Dear Sir / Madam,
We checked Nebula Device status On, but cannot reboot device, please advise us. Thank you.
Group: Cyber
ORG: Tinson
SITE: TW
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,338  Zyxel Employee
    Dear @Cyber_IT
    Thanks for your inquiry.
    Please navigate to Site-wide > Monitor > Devices > Firewall and scroll down to Live Tools.
    Chose the Reboot device tab and click the Reboot button.
    If you still have a problem with this, please enable Zyxel support for us and we can check it for you. Thanks😉.
  • Zyxel_Jeff
    Dear @Cyber_IT
  • Cyber_IT
    DearJeff,
    Thank you for reply.
    But i am use VPN100 and VPN300 Nebula SDWAN, i already try to click reboot device in site > monitor > troubleshooting, but device haven't reboot and reboot time is shown before reboot time. Thank you.
  • Zyxel_Jeff
    Dear @Cyber_IT
    Is it only the site TW that cannot be rebooted from the Nebula Orchestrator, or are there other sites that cannot be rebooted as well?
  • Zyxel_Jeff
    Dear @Cyber_IT
    Please update the firmware to our latest version and see if the reboot button is working for you. Thanks.
  • Cyber_IT
    Dear Jeff,
    I tried not only TW site, HK site device also cannot reboot via nebula, also click upgrade cannot upgrade. Please advice us.
  • Zyxel_Jeff
    Dear @Cyber_IT
    OK, got it. We will check it. Please wait for my update.
  • Cyber_IT
    Dear Jeff,
    is there have any updates on the case? Thank you.
  • Zyxel_Jeff
    Dear @Cyber_IT
    We are checking on this, please wait for our update. Thanks.
  • Zyxel_Jeff
    Dear @Cyber_IT
    This issue was already been resolved, thank you for your patience for us.
Nebula Tips & Tricks
