Access point NWA50AX
Billetiere
Billetiere Posts: 4  Freshman Member
device statut : Alert
An error is detected
quel problème ?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    edited August 2023 Answer ✓
    Hello @Billetiere
    If you are referring to the alert status with the orange icon as shown below, is the message "An error is detected" what appears when you hover over that icon?
    To pinpoint the exact error, please share with us a screenshot of the alert on the AP by clicking on the AP, which will display the AP details page.
    One common cause for this alert status could be a 10/100Mbps link speed. Guidance on this specific issue can be found in the following FAQ: Nebula - How to check the AP status on NCC.
    Nami
  • Zyxel_Nami
    Hello @Billetiere
    Nami
  • Billetiere
    problème nr7101 pas accès internet
Nebula Tips & Tricks
