NR5103E scheduled reboot option
I have an NR5103E. Sometimes the internet connections turns slow or not responding, and problem can be resolved by simply reboot (using the reboot from admin panel).
May I ask is there an option of scheduled reboot? Let say schedule reboot at mid-night everyday. That will make our lives much easier.
Thanks.
I use the FW V1.00(ACDJ.0)C0
And it did not have the schedule reboot function.
If you purchase the machine from the ISP, then maybe you can ask them for this feature.
For me, I use the Zyxel Air APP to reboot the device.
I only need to open the APP and click reboot before I go to sleep which takes me less than 30 second.
Thanks for advice.
I'm using firmware V1.00(ACBJ.0)b12. I tried Zyxel Air App, but it says "Can't find your Zyxel Device". Same error if I try manual mode and input the address and port myself. Is there some setting I need to enable in web GUI first before I can use Air App?
I connect to NR5103E's WiFi and use auto mode to log in.
Type in the user account and password then I am able to use Zyxel Air APP to control NR5103E.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
