NR7101
@vampire survivors It is possible that the NR7101 is not fully compatible with the WindTre network or there is some other configuration issue with the router. You can fix it by checking the signal strength NR7101 is receiving a strong signal from the WindTre tower. You can do this by checking the signal strength indicator on your router or by using a mobile app that displays signal strength.
Hi everyone, please help. I need to set up my nr7101 I have the latest firmware I am struggling set it up. Im in Poland and my internet provider is T-mobile I have faster connection on my 5g mobile then in zyxel router
I really appreciate any help
- 602 USG FLEX H Series
- 480 News and Release
