Name of connected SSID in client list ?
hfr_dk
hfr_dk Posts: 4 image  Freshman Member
It seems no longer possible to see SSID that a client is connected to in the client list overview (site wide → Clients) Is that correct and if yes how can the information be found ?
Side question: Is it possible to disable the navigation sidebar and instead have the old menu ?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @hfr_dk
    To view the SSID name to which a client is connected, you can navigate to the Clients > Client List tab. Once there, select Access Point Clients and click on the icon located on the right side, as shown in the screenshots below.
    As for your query about the navigation sidebar, Nebula underwent a UI enhancement in the 17.00 release back in April. Unfortunately, the old menu can't be reverted. May I ask why you'd prefer to disable the sidebar and use the old menu?
    Nami
  • Zyxel_Nami
    Hello @hfr_dk
    Nami
  • hfr_dk
    Thanks @Zyxel_Nami very helpful, much appreciated.
    In regards to the UI sidebar. I prefer the old one since the graphic icons alone without additional text are not self explanatory, this means that I have to click on several icons before I find what I am looking for. Adding a short text next to the icon would improve the experience significantly or having the possibility to keep the sub menu permanently expanded would also help.
Nebula Tips & Tricks
