GS1915-8EP had offline on NCC
My switch, GS1915-8EP work normally, status online on NCC and had lasted firmware
a few days ago, it suddenly went offline on NCC until today, still not online again
connected devices behind it, seems to be working properly, including APs, status are online on ncc
I can not connect to my switch on local, it seems don’t have a ip, i can't find it with ip scan tool
Please help me, thanks
Best Answers
ZON utility can scan my switch, it’s IP is 0.0.0.0
After settings static ip, working now
I don’t know why have problems with DHCP IP
Hi @Tlml,
The switch's IP is 0.0.0.0 could be due to the DHCP pool size running out. You can set static IP or enlarge the DHCP pool size.
For the switch offline problem, did you reboot the switch between August 26 - 27?
Zyxel Melen0
Hi @Tlml,
Zyxel Melen0 -
Hi @Zyxel_Melen
i don't think DHCP pool size is over, the DHCP size = 251, and less than 30 devices
I have restarted the switch and router many times, tried unplugging all cables... and also try ip scan and ip scan tools
it was only solved when i used ZON utility, i was so happy when it appeared on the list i know the problem is solvesolved. i know the problem is in the ip, but i cant find the device to set it static ip
Hi @Tlml,
I'm glad to hear that your issue has been resolved. If the switch is offline again, please reference this FAQ first:
Zyxel Melen0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
