[NEBULA] VPN IPSEC with L2TP works for Android but not for Windows 10
Hi Guys, i configuerd the client to Site VPN with L2TP on my NSG50 with nebula authetication, i can connect my android phone to the NSG over VPN but not my Win10 Laptop. i enterd the preshared key and username/password but on evrey try i get an error massage. i also tried with Zyxel VPN client, but this is also not working. Is there a how to or somthing else?
Hi @Sascha
Welcome to the forum
As @TomorrowOcean says L2TP IPSec on Windows 10 problems are known.
Quick solution is to execute, and reboot the pcREG ADD HKLM\SYSTEM\CurrentControlSet\Services\PolicyAgent /v AssumeUDPEncapsulationContextOnSendRule /t REG_DWORD /d 0x2 /f
But I suggest to read the following links:
https://superuser.com/questions/1298513/l2tp-ipsec-vpn-fails-to-connect-on-windows-10-works-fine-on-ios
https://github.com/hwdsl2/setup-ipsec-vpn/blob/master/docs/clients.md#windows
I hope it helps you.
Best regards
7
I had the same problem before I saw the post
https://businessforum.zyxel.com/discussion/1999/connection-vpn-l2tp-over-ipsec-from-windows
Maybe you may try it first.
Hi @Sascha
Best regards
7 -
Hello @Sascha
Welcome to Nebula Community!
I'd like to thanks @TomorrowOcean and @Alfonso to sharing their idea.
Please feel free to let us know if the issue still persist.
Cheers~
How about the connection with Zyxel VPN Client to Nebula NSG. I cant find any discripton about that how to connect the VPN Client to the Nebula NSG0
I think the Zyxel VPN client doesn't work with the NSG, but maybe Chris can double check.
Anyway, setting L2TP VPN up in android/iPhone shouldn't be complicated... Easy Peasy!"You will never walk along"0 -
Hi @Sascha
In current stage NSG not support Zyxel VPN client but I think it would be more easily to use L2TP connection since it is also encryption and built-in in Windows OS.
/Chris0 -
Hi alle thanks for the support. Yesterday i deployed the the L2TP connection on site at the customer.
With Win10 QuickFix soluotion it works grate.2
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 399 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 78 Security Highlight
