Using an SCR 50AXE as standalone AP (only)?
Hi @neukrisz
Thanks for the feedback.
There is no AP only feature on SCR 50AXE.0
Hi @neukrisz
The SCR 50AXE model will not include the MESH feature. For extending WiFi service, an Ethernet connection will still be required.
However, we have a plan to add mesh system in future products.
If you have any further inquiries or suggestions, please feel free to let us know.0 -
Thanks for your reply!
Without MESH can we use that as standalone AP only? (so has it AP mode only?)
Thanks in advance!
Hi @neukrisz
There is no AP only feature on SCR 50AXE.0 -
Thanks!
Is there any plan for implement this feature in the future?
You could use as an AP, make sure DHCP is off and give the LAN interface a suitable free static IP, and Bingo you have an AP. Devices that join the Wi-Fi will get an IP address from your LANS DHCP server.
I bought this router in the assumption that an enterprise grade AP wouldn't miss such a function but it does. Now I hope your suggestion can help me. But so far I haven't been able to get this to work. I disabled the DHCP server on the Zyxel. I configured an IP address in the same window where you configure the DHCP server that is within the subnet configured on my OpnSense server.
But it doesn't even matter if I connect the Zyxel to any of the 4 LAN interfaces or the WAN interface, no result. I can connect with my devices but no internet, no LAN access.
Also, if I connect the WAN interface to the network, the nebula led lights up yellow. If I connect it through one of the LAN interfaces, the nebula led doesn't even light up. All my devices have internet over the same switch.
Wether I connect over the old or new access point, I can't connect to the IP address of the Zyxel either.
Have you got any idea?
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
