How to automatically reboot the NR5101 by schedule
Termidk
Hi
I would like to reboot my zyxel NR5101 at 05.00 AM every sunday morning.
I have found some shell commands like :
As example the following for a reboot:
- Login into the Zywall/USG via console/telnet/SSH.
- Enter the following commands:
configure terminal
reboot - Save the file as reboot.zysh. It's only important, that it's file extension is zysh.
- Upload the script on the Zywall/USG.
Setup the schedule for the script
Router# configure terminal
Router(config)# schedule-run 1 reboot.zysh weekly 10:00 sun
The device will reboot every Sunday at 10 o'clock.
I can telnet to my NR5101 just fine but the above commands do not work here.
Can somebody give me a guide to make it work, please :-)
Kind Regards
I dont think NR5101 can use the command to do it because there are different products than Zywall/USG.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
