SNMP MIB for NR7101
Is there a MIB out there for the NR7101? Have enabled SNMP, and I can successfully monitor network data, but was wondering if I could als get some hardware health data.
Hello @Krist
I have not been able to find a Zyxel page with information.
But the following link might help you with Object Ids.
https://mibs.observium.org/mib/ZYXEL-SNMP-MIB/
Paessler might have tools that could help you discover the MIBs, see https://www.paessler.com/info/snmp_mibs_and_oids_an_overview?gclid=CjwKCAjw38SoBhB6EiwA8EQVLoMlCFPoPsjV8P2gdgjfoH6w0-LrNGjLt55zPfSuwIBD6RsVOgPJJxoCDfoQAvD_BwE , and its PRTG product could do an SNMP WALK for you.
https://geekflare.com/best-mib-browsers/ survey of 8 MIB browsers that could allow you to discover the MIBs of the NR7101 interactively.
https://github.com/Poil/MIBs/blob/master/zyxel/ZYXEL-MIB also gives you some idea of MIB Object Ids (OID) for Zyxel, though it is not upto date for modern products like the NR7101.
https://www.iana.org/assignments/enterprise-numbers/?q=zyxel shows that 890 is the private enterprise OID for Zyxel.
Private Enterprise Numbers (PEN) are identifiers that can be used in SNMP configurations, in LDAP configurations, and wherever the use of an ASN.1 object identifier (OID) is appropriate.
The PEN prefix is 1.3.6.1.4.1.
Although it says it is related to Zyxel Nebula, the OIDs at https://support.zyxel.eu/hc/en-us/articles/4411475992594-Nebula-SNMP-Configuration-Monitor-your-Device-via-SNMP#two could be useful to you as it lists some common OIDs for Zyxel devices.
I hope that this is helpful.
Kind regards,
Tony
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
