Error when attempting config backup of AMG1302-T10B
IJ9901
IJ9901 Posts: 2 image  Freshman Member
I have done a factory reset of the router. After I restored the backup I tried to do a new backup but got the error below. I then upgraded the firmware to 16 but still error.
404 Not Found
The requested URL /romfile.cfg was not found on this server.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    I recommend that you can reset to the factory default first and modify the configuration again, and then try to backup the configuration again to see if the problem is solved.
