NR 7102 Remote connection
Hi im thinking if its possible to have a free service like noip in my router to login from any where easy,
Because i tried with noip but didnt work
Im using 5g sim so i have already always internet so i want access from anywhere.
Did you open the Remote management in WAN interface?
Yeah i had port 90 as http but wan was not enabled, now i make the same as your picture and i open wan on https and https with same port but dont work,
also i confirmed that i get public ip on dyndns,
see0 -
Any idea why cant enter remotely ?
Yeah i had port 90 as http but wan was not enabled, now i make the same as your picture and im open wan on https with same port but dont work,
see the screenshots.
status:
Service control:
Can you do the trace route to the device's WAN IP?
To check whether it is able to reach the WAN IP of device.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 452 News and Release
- 4.3K FAQ
- 93 Security Highlight
