Locate which exact LAN port is used by a client
GiuseppeR
GiuseppeR Posts: 386  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
I have a network where I see a lot of devices connected.
Looking into the Site-wide > Clients area I can see all the clients, I can see which switch is connected to but I cannot see which exact port is used.
Is there a trick to get this info quickly?
Thanks in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,277  Zyxel Employee
    edited September 2023 Answer ✓
    Hi @GiuseppeR,
    If you change to the Switches clients page, you will find there's a column showing which port the client connected to the switch. If you do not find the column, please check if the port column has been selected.
    Zyxel Melen
  • ivessm
    ivessm Posts: 45  Freshman Member
    GiuseppeR if you go into Site-wide > Devices > Switches > the particular switch the client is connected to and then slide down to Ports you will see the active ports on the switch. If you mouse over those ports it will tell you who/how/etc the port is connected.
    Let me know if this helps.
    -stew
  • GiuseppeR
    @ivessm
    thanks for the trick but let me add another trick. 😎
    To see the list of MAC addresses connected to a specific port the user has to click on that port to explore everything that is connected, otherwise it is not possible to look for a specific MAC address while simply hovering with the mouse above an icon.
  • Zyxel_Melen
    Hi @GiuseppeR,
    Zyxel Melen
  • GiuseppeR
    @Zyxel_Melen
    Your trick is the quickest one, my compliments.
Nebula Tips & Tricks
