Locate which exact LAN port is used by a client
I have a network where I see a lot of devices connected.
Looking into the Site-wide > Clients area I can see all the clients, I can see which switch is connected to but I cannot see which exact port is used.
Is there a trick to get this info quickly?
Thanks in advance
Hi @GiuseppeR,
If you change to the Switches clients page, you will find there's a column showing which port the client connected to the switch. If you do not find the column, please check if the port column has been selected.
Zyxel Melen0
GiuseppeR if you go into Site-wide > Devices > Switches > the particular switch the client is connected to and then slide down to Ports you will see the active ports on the switch. If you mouse over those ports it will tell you who/how/etc the port is connected.
Let me know if this helps.
-stew
thanks for the trick but let me add another trick. 😎
To see the list of MAC addresses connected to a specific port the user has to click on that port to explore everything that is connected, otherwise it is not possible to look for a specific MAC address while simply hovering with the mouse above an icon.
Hi @GiuseppeR,
Zyxel Melen0 -
Your trick is the quickest one, my compliments.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
