Nr7101 poe injector protocol
My poe injector that came with the modem broke. I am looking for replacement.
Is an af protocol enough or do I need an at injector?
Also will an injector following both protocols work in this case ?
Hi all,
You need an 802.3 af/at Power over Ethernet injector according to the specifications at https://www.zyxel.com/uk/en-gb/products/mobile-broadband/5g-nr-outdoor-router-nr7101/specifications to supply < 16W.
More details about the PoE specifications is at https://community.fs.com/blog/understanding-poe-standards-and-poe-wattage.html
Has anyone replaced their poe injector and with which one that works
Hi all,
thanks
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
