AX1800 Wi-Fi 6 Router Does not Work
I bought AX1800 Wi-Fi 6 Router yesterday and I tried to use that. I connect the ethernet cable to WAN port, and adjust the wi-fi settings(password, name, etc) from 192.168.123.1 website. When I check from that website, internet connection seems fine but router keeps blinking red light and I can connect the internet. Can you help me about that. You can see the connection in the image.
It appears that you are in router mode and have connected an Ethernet cable to the WAN port, which is linked to your PC. To resolve this, you should connect the Ethernet cable from the WAN port to your ISP's router and use the LAN port to connect your PC or laptop
Hello @erenduman
Welcome to the forum.
What is the model number of the AX1800 device you have please? DX3301 for example?
Is it the Internet LED the one that is going Red?
Looking at the user guide from https://support.zyxel.eu/hc/en-us/articles/5858783065362-User-Guide-AX-DX-PX-3301-T0-Serie-V5-13-5-50 which I think is relevant, it might be good for to look at the logs i.e. System Logs, of your device through the web configurator.
The logs might show why your Internet WAN connection is failing, as far as your device can tell.
Kind regards,
Tony
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
