GS1910-24 & 24hp
hello I have a GS1910-24 and 3 GS1910-24 hp switches.
I had to factory reset all and all have original firmware which is far outdated. I can’t even configure vlans which I need.
How do I upgrade to current verison? I tried to install it but it says it’s the wrong file.
Please help.
Hi @Danoutlaw3,
Please follow the below steps to factory reset your switches:
1.) Enter "Ctrl+C", while booting.
2.) Enter "default" to reset to default.
3.) Enter "reset" to reboot and wait for config re-generation
4.) You can find the password and configuration have been reset.How do I upgrade to current verison? I tried to install it but it says it’s the wrong file.
Please find the correct firmware file in the below post.
Zyxel Melen0
Hi @Danoutlaw3,
Zyxel Melen0 -
Thanks I keep getting "Invalid Firmware Image
The uploaded firmware image is invalid. Please use a correct firmware image."
yes that’s what I’ve done, still get this error.
Hi @Danoutlaw3,
GS1910 series needs to follow the upgrade flow. Please check the flow below to upgrade.
GS1910-24:
GS1910-24HP:
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
