Create Zone UGS20-VPN
Hi @baudetd
Because the USG20-VPN only has lan1 and lan2 two lan zones by default, therefore needs to manually create lan3 zone. Please refer to this FAQ article How to configure LAN3 zone on USG20(W) and USG Flex 50(W) models? Thanks.
Do you not have a User Configuration place for adding a zone?
where is User Configuration place ?
I'm in administrator mode
configuration > object > zone
hello
I will explain my request,
I want to create an independent network on port P3.
I associated my LAN configuration to port 3
but for the rest, I created a new zone but it does not work...do you have a procedure0 -
With the new zone set for P3 you then need to add a firewall rule for that from zone to get out your WAN
hello
I can't find the problem
I already have a LAN2 which works on port 4
This is how the control policy is configured for the LAN
the only difference between lan2 and lan 3 is that I don't have the same zone config
That should work you do have P3 set with zone LAN3?
Maybe you need a routing rule
incoming LAN3
next hop WAN
also check your port role in interface that the port set for that zone
Good morning
the problem is with the role
if I add the lan3 in the lan 2 role
it works
configuration User configurationis different from the Config configuration. system default
why is it not possible to add a role in the default config?
Hi @baudetd
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
