VMG3925-B10B Multicast
I have a problem with three multicasting devices not able to communicate via multicast when connected to Wifi on VMG3925-B10B. The devices are two Defa Power EV-charging stations and Defa Balancer -load balancing device. All the devices are connected to the router, they can be seen in the GUI. On router settings, LAN-LAN multicast is enabled, IMGP snooping is turned on. Multicast is set to normal mode, not blocking. When trying to pair the devices (make a multicast group with their own configuration app), in IMGP status screen on the router, those devices show up with their Filter mode as ”EXCLUDE”. I cannot find any setting to include these devices in a multicast group. Is there any more detailed settings for multicast? Or isn’t the router supporting multicast via Wifi? Can anyone help me with the problem? Thanks.
Hello @fimiikar
Welcome to the forum.
Are you able to say what firmware version you are running please?
There is a user guide at
It says the following:
I don't see a way to set-up a Multicast group in the VMG3925-B10B…at least not in 2015 user guide.
Are your devices joining the 224.0.0.1 group to hear the query messages?
You might want to enable the Enhanced Multicast Forwarding (see below)…
I hope that this is helpful. Please let us know what you think.
Kind regards,
Tony
- 601 USG FLEX H Series
- 480 News and Release
