Create Zone UGS20-VPN
baudetd
baudetd Posts: 43  Freshman Member
hello
i want to link an interface to a zone but i cannot create zone ...thanks
    PeterUK Posts: 3,799  Guru Member
    Do you not have a User Configuration place for adding a zone?
  • baudetd
    where is User Configuration place ?
    I'm in administrator mode
    configuration > object > zone
  • baudetd
    hello
    I will explain my request,
    I want to create an independent network on port P3.
    I associated my LAN configuration to port 3
    but for the rest, I created a new zone but it does not work...do you have a procedure
    With the new zone set for P3 you then need to add a firewall rule for that from zone to get out your WAN
  • baudetd
    edited October 2023
    hello
    I can't find the problem
    I already have a LAN2 which works on port 4
    This is how the control policy is configured for the LAN
    the only difference between lan2 and lan 3 is that I don't have the same zone config
    edited October 2023
    That should work you do have P3 set with zone LAN3?
    Maybe you need a routing rule
    incoming LAN3
    next hop WAN
    also check your port role in interface that the port set for that zone
  • baudetd
    Good morning
    the problem is with the role
    if I add the lan3 in the lan 2 role
    it works
    configuration User configuration
    is different from the Config configuration. system default
    why is it not possible to add a role in the default config?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,320  Zyxel Employee
    Hi @baudetd
    Because the USG20-VPN only has lan1 and lan2 two lan zones by default, therefore needs to manually create lan3 zone. Please refer to this FAQ article How to configure LAN3 zone on USG20(W) and USG Flex 50(W) models? Thanks.
