MCC/MNC 99999 support on Mifi devices
vandobeln
Our testing shows that ZyXEL LTE3301-Plus -LTE does not attach to a B40 private network with MCC/MNC 99999.
Is there a fix? Does Zyxel have other (preferably CAT 4) devices that support private mobile network codes?
First, band 40 is supported in LTE3301-PLUS.
Second, do you fill in the APN on the web GUI manually? Just want to make sure the configuration is correct.
Regards,
Bob
The APN was configured, but the device did not even try to attach to the network.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
