MCC/MNC 99999 support on Mifi devices
vandobeln
Our testing shows that ZyXEL LTE3301-Plus -LTE does not attach to a B40 private network with MCC/MNC 99999.
Is there a fix? Does Zyxel have other (preferably CAT 4) devices that support private mobile network codes?
First, band 40 is supported in LTE3301-PLUS.
Second, do you fill in the APN on the web GUI manually? Just want to make sure the configuration is correct.
Regards,
Bob
The APN was configured, but the device did not even try to attach to the network.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
