VLAN issue with NWA50AX PRO
I'm at my wit's end on this one. I have 3 VLANs (10, 20, 30) set up on my OPNsense box. I have those same 3 VLANs configured on my managed switch (tp-link TL-SG1024DE).
All wired connections work as expected - I am connected to the appropriate VLAN, receive the correct IP address, and can access the internet.
If I connect wirelessly to my Zyxel AP, the only way I can get internet access is if I leave all of the default VLAN settings (VLAN at 1). If I do that, it drops me onto the incorrect IP range (the default LAN - 1 - 192.168.1.x instead of VLAN 10 - 192.168.10.x), though I do have internet access. If I change the VLAN tag on the AP to match (e.g. 10), it all breaks. I can see a correct IP address being assigned by the router (192.168.10.x), but there is no internet access by any device connected wirelessly when I change the VLAN away from the default of 1.
What am I missing? Why will all of my VLANs work properly with wired connections, but not work (no internet) if I try to configure the VLANs on my Zyxel AP?
Scratch this issue. Finally got it figured out. Strange interaction with OPNsense was the culprit.
Hello @soconfused
It's good to hear that you resolved the issue. Regarding the VLAN setting on the AP, we have included the FAQ below. You may refer to it to understand more about the VLAN settings on the AP.
Nami
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
