Zyxel NSA310S can't create directorys
Hello
I've tried to be the local admin with the full rights. I can create within browser but when I connect via Filezilla FTP, it is saying 550 Can't create directory: No such file or directory. I'm trying to create a new folder into / (root).
This makes me crazy, my Reolink IP camera won't save footage there too because it is saying almost the same (disk full or not enough permissions) but I am using the built-in account with full permissions!!!!
Please help!
At the same level as the shares? That won't work, you can only create directories within a share. The root doesn't really exist. Shares can be on different volumes (well, not on a NSA310, but on a multidisk NAS), so the root would be undefined.
Okay!
Other way it works, if I try to make a folder in admin folder, that works BUT my Reolink camera still won't do it. I type the path /admin/video and type in my user and password but it just says that I need to check if HDD is full or if I have permissions. All 2TB is free and permissions are FULL.
What to do?0 -
I'd have a look with either filezilla server or wireshark to see what the camera is trying to do. Maybe it just can't handle a mandatory subdirectory.
I see from Zyxel that the camera is logging in with the credentials but logs out again. Any tips how I can use FileZilla to see how other devices are connecting?
What do you mean? The logging of Filezilla server is quite extensive. At least it's on the Linux version. So you should be able to see what the client is doing.
- 603 USG FLEX H Series
- 481 News and Release
