NR5103E - HOW TO CHECK NR CONTRIBUTION TO UPLINK PERFORMANCES?
Hi everyone,
I am at the edge of a 5G cell with RSRP-NSA around -107 dBm (N78 band).
The NR5103E shows that both LTE (primary/anchor) and NR bands are being aggregated, hence supposedly contributing to uplink performances… unfortunately it seems that NR is not adding value as uplink performances remain the same when I turn 5G N78 band off!
Question: is there any way to measure 5G contribution to uplink performances? Why UL CA is shown even if performances show the opposite?
Thanks!
What do the blue lights mean?
Hi lucapagliuca,
I don't have a better way to measure how much the NR cell contributes to uplink throughput than your way (compare the speed with and without N78 connection).
But as you mentioned, N78's RSRP is -107 dBm, meaning that you're at the edge of the cell. Uplink speed is more vulnerable to signal variation than downlink speed because uplink works from end device to base station, and end device has relatively limited power to boost as compensation if the signal degrades.
I'd suggest to align it to the base station again, try to find the optimal alignment. For example, switch the device a bit, check if the signal is better. Also, try to locate it at different spot of the building, see if the signal becomes better.
Regards,
Bob
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 84 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 915 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
