usg20w-vpn drops internet on wan interface every 45 minutes
HI,
running usg20w-vpn with latest firmware. this setup was working for years behind a surfboard8200 modem and comcast internet. we upgraded service to 500mb and now internet signal drops after 45 minutes and does not return w/o reboot. comcast says it is firewall. how can i get more details from firewall device?
when internet drops, i can connect to usg web interface from internal devices still when at office.
any thoughts on what may be occurring or direction to research?
thanks.
…I also tried with comcast business modem in router mode and cascade to usg but usg still drops.
tried comcast device in bridge mode and drops. tried a different netgear brand router also and still dropped at 45 minutes.
Do pings drop? Run
ping -t 1.1.1.1
Do a packet capture on USG for the WAN note make captured packet files size big then when it drops on a idle connection with ping look at ARP the DHCP
another thing you can do is put a switch between modem and USG to see if thats stable.
Hi @udoc
We suggest you check the monitor log(Monitor > Log) to see if there are any suspicious logs during the internet drop. Besides, when the internet drops which device do you reboot it? Is the usg20w-vpn or SURFboard 8200 modem?
Here's an unusual situation: even if you use a different brand of router, the internet still drops every 45 minutes. This could be related to the ISP environment or the modem. Thanks.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
