Modem firmware for Nr5101
tailele
Good morning, I am the owner of a Zyxel Nr5101. I am quite satisfied with the modem, I have seen that there have been several upgrades for the browser interface, however the modem firmware has remained at the version from 2 years ago. Unfortunately with this version it is possible to aggregate only one 4G band when connected to the 5G N3 band. I wonder why it is not possible to install the latest version of the broadband firmware (which is also used in the Mikrotik Chateau 5G), which allows you to aggregate different 4G bands also using the N3 band. I am also available to act as a beta tester in order to solve this problem which is currently creating various inefficiencies for me, especially because I have to disable 5G as the signal becomes really poor. Thank you
If you want to upgrade module FW, I think you can ask technical support from Zyxel Networks support center.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
