Router Zyxel EX3301-T0 static IP address for wired device
I did assign a static IP address 192.168.1.3 for a device, with a known MAC address,
which was connected by wire to the router.
That was done via "Home networking" → "Static DHCP".
However, in the page "System" → "ARP Table", the MAC address was bound to a
different IP address. So the static binding did not work.
I also tried to reboot the router, and the device, and even tried to decrease the DHCP
lease time to 2 minutes. But nothing of that helped. The device persistently got the same
IP address, and not the one I had defined.
Interesting though, is that static IP addresses for wireless devices work!
Do you know a solution to this problem with wired devices?
Hi
Could you please report to your ISP or Zyxel local support?
Hello @HarryDualBeard
Welcome to the forum.
If you are still having the issue, are you able to say what version of firmware is running in your EX3301-T0 device please?
There was a new version of firmware published in October 2023 that is available for download at https://www.zyxel.com/uk/en-gb/support/download?model=ex3301-t0
Kind regards,
Tony
Thanks for info.
I suspect that the firmware may be isn't the latest. (It wasn't when I checked it a few weeks ago.)
The ISP is handling the updating. I can't do it myself.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
