Nebula DNS and access Router WAN
two questions.
Question one:
i had change the router and work now with nebula. Before nebula i must change the DNS configuration because the connection breaks temporary down.
After that, all devices work fine.
Now i have the same issue. So i think, i must configure this in nebula too.
But i can't save. What am i doing wrong?
Question 2:
On WAN1 is a AVM Fritz!Box. DHCP work. But i can't ping the router ip as well as i can't access the web interface.
I hope you can understand my not very well english.
Best regards
Ray00731
You can execute the command to solve this problem
Router(config)# ip dns server zone-forwarder insert 1 * user-defined 8.8.8.8 interface auto
Please note that DO NOT enter “write” after executing the command, otherwise, the device will become standalone mode.0
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
