NWA50AX isolation des clients wifi
Bonjour,
Je souhaite savoir s'il est possible d'activer l'isolation des clients connectés sur le point d'accès Wifi Zyxel.
Firmware Version:V6.25(10) / 2022-06-17 00:39:38
NWA50AX
Serial Number:<hide due to privacy>
En effet je ne souhaite pas qu'ils ne voient ou n'aient pas accès aux ressources de mon réseau local, uniquement un accès à internet.
Hello @Franz94370
To isolate wireless end devices on your NWA50AX from each other and the local network, while allowing internet access, you can utilize Layer 2 Isolation feature.
Please upgrade your device to the latest firmware version as 6.29(ABYW.2)C0 to access this feature. After that, you can follow the below FAQ for configuration steps:
Access this download library to download the firmware.
Note: Layer 2 Isolation blocks communication within the same subnet but not across different subnets. If your SSIDs are on the different subnets, the isolation requirement should be done by switch or firewall.
Nami
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
