NR5101 without Nebula and wpa3
Hi @ilario ,
is it possible to use wpa3 in Nr5101 router device without nebula?
You have the option to use WPA3 with both Nebula NR5101 and non-Nebula NR5101 devices. To do this, navigate to Network Settings > Wireless > Security Level.
Note that: Choose WPA3-SAE if all your WiFi clients support it. If you're uncertain about your wireless clients' compatibility, selecting WPA3-SAE/WPA2-PSK or WPA2-PSK alone is a relatively safe choice.
can nebula be installed in the NR5101 device without nebula?
The Nebula portal is exclusively compatible with Nebula devices.
FYI: To determine if your Mobile Router is Nebula-compatible or not, please refer to this FAQ.
Zyxel_Judy
Hi @ilario ,
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
