EX3301-T0 port forwarding issues
I've just recently had fibre installed and it came with the EX3301-T0 router. I'm having trouble setting up port forwarding and would appreciate some help. I have a NAS that has some functions I want to access from outside my network and on my previous broadband setup I had port forwarding enabled to the appropriate NAS IP and port and it all worked. On the Zyxel I've set up a port forwarding rule to the NAS IP on the same port but I can't get any connection to it from outside my network?
Is there anything else I need to configure to get port forwarding working?
if its port 80 or 443 it might be blocked by your ISP or hopefully not the router due to web login port
Thanks for the reply. No, it's neither of those those ports. It may still be the ISP though. I've raised a ticket with them, so coming at this from a couple of different directions.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
