VMG8825-B50: new separate wifi network andInterface Group
I have a Zyxel VMG8825-B50 with firmware version 5.17(ABNY7)C0 connected in LAN to LAN cascade to the main router of my internet provider (Sky Wifi with FTTH fiber)
I made the following configurations
- I set fixed IP 192.168.1.4
- I disabled DHCP
- from the "Network Settings->Broadband" menu I disabled ALL WAN services
- I created a 2.4Ghz/5Ghz WIFI network with SSID WIFI2
- from the "Network Settings->Wireless->Guest/More AP" menu I created a new wifi network called WIFI3 (no guest)
- from the "Network Settings->Interface Grouping" menu I created a new group called OTHER_WIFI adding only the LAN with SSID WIFI3
- from the "Network Settings->Home Networking->LAN Setup" menu I selected OTHER_WIFI from the "Interface group" menu and created a 192.168.2.X subnet separate from the main 192.168.1.X.
- I activated DHCP for these 192.168.2.X addresses
- I saw that there are now two network interfaces called br0 (192.168.1.X) and br1 (192.168.2.X)
If I connect to WIFI2 with any device I correctly receive an IP from the DHCP of the main router and surf the internet.
Problem: if I connect to WIFI3 with any device, I correctly receive an IP address of 192.168.2.X but I am unable to browse the internet. Does it depend on the fact that in the OTHER_WIFI group I have set the "ETH_WAN" value as "WAN Interface" which, however, is not correctly configured for internet browsing via the main router? Being able to access the VMG8825-B050 as root.. maybe with some "iptables" rules on br1?
Thank you
Stefano
I recommend that you have to enable WAN service.
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
